TwinTurbo.NET: Nissan 300ZX forum - Ok Got timing Set at 15 degrees but getting rough idle
Subject Ok Got timing Set at 15 degrees but getting rough idle
Posted by blkrocket on January 14, 2011 at 12:22 AM
  This message has been viewed 120 times.
Message OK so I have been troubleshooting a rough idle issue. I check the EGR (Good), AAC Valve Assembly (Seems to work fine), Injectors are clicking and all vacuum hoses are in good shape.
I do not know how to set the AAC Valve correctly though. Spark plugs are NGK PFR6B11 (Seemed OK but could be dry carbon on them - will check again after running the car).
The weird thing is that the timing will periodically jump from 15 to 30-35 degrees when the car is all warmed up. Anyone know why this is this happening?
